Discuss Quickest drying wall filler for largish hole (before tiling) in the UK Tiling Forum | Tile Advice Forum area at TilersForums.com
I'm might have ballsed up here...
I was planning to patch up a few holes like this one before it gets tiled in just over a week or so (could be less):
I had thought to use mortar, but now I'm thinking that might take too long to cure enough for tiling over (more than happy to be corrected if I'm wrong!!)? If I'm right, is there anything else I can use that could be dry/cured well enough in 5-7 days+?
I'll get there one day!
Cheers
OP
Great... I'm going to be using low expanding foam around the frame to seal it, so it would be a quick and easy solution to use it for the gap too. I had wondered but wasn't sure if the gap was too large?
Many thanks
Upvote 0
OP
Actually, someone reminded me about Toupret fillers... I'd kind of forgotten. I've used Le Reboucheur in the past after having read how much pro decorators rate it, and I too thought it was excellent stuff. Not used it for a few years, and so forgot that it says there's no maximum depth. I'm not sure if another one of their other fillers - TX110 - was about when I bought Le Reboucher, but with a quicker setting time and no limit to the application thickness, I'm gonna give that a go and see how I get on. .
Cheers for taking the time to respond
Upvote 0
Joy1979
Many thanks
expanding foam around the frame but not the wall as looks far too big and foam not a solid background, depending on the depth could just build out with rapid set adhesive and bridge with AFM
Upvote 0
Reply to Quickest drying wall filler for largish hole (before tiling) in the UK Tiling Forum | Tile Advice Forum area at TilersForums.com
Similar threads
  • Question
Hi. I've just had the bathroom re-plastered and will be tiling soon. We have a shower above the bath and are wondering about what to use to waterproof before tiling. The plan was to use the mapei waterproofing kit on the walls (but not the tape as from what I've read this can peel off the edge...
  • Question
Hi tilers We're having a shower bath fitted soon and will be tiling around it. They are all solid walls (one is a solid single skin internal wall, the other two are external cavity walls). They were tiled previously, but all the tiles have now been removed and it's back to plaster ready for...
  • Question
Good morning, I've used this site a number of times for tiling info and have always found it really useful, but this time I wanted to post a question before I start a tiling job. I am about to start work on our en-suite shower. I need to remove the old tiles and (no idea what is under there i'm...
  • Question
Hi All Looking for a bit of advice if I may? I recently embarked on a project to replace the bath in the en-suite with a shower, but once the state of the flooring became apparent the project grew legs and the whole room got gutted! I have replaced all the OSB with 18mm ply, due to...
  • Question
Hi all. So I have just finished laying my 600 x 600 x 20 mil porcelain tiles in the back garden over a type one base. One of the tiles I was running short on cement and so I did a sort of dot and dab thing which didn't work in the slightest and came loose the next day. There was still quite a...
Tiling Courses
Workwear for Tradesmen
Mapei Tile Adhesive and Grout
uHeat
The Wetroom Store for all Wetroom Installations
Nicobond Tile Adhesives and Grout
Latest 10
Thanks for visiting TilersForums.com, formerly known as TilersForums.co.uk.
Search Forum
