Discuss Pvc ceiling and then tile walls, or tile walls and fit the ceiling after? in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Never done a pvc ceiling before but would make more sense to fit the ceiling first then tile to it, other wise you would have to be pretty exact with the ceiling sheets. Cheers
I've not done pvc cealing, but I use to make them in aluminium. We use to tile first then rest the cealing on top of the tile edge, not sure if it will work with pvc as I didn't use it. Would be good if you share the way you'll do and the experience, allwais good to learn !
D hug
I decided to Pvc the ceiling first and then tile up to it. Seems good
How is the pvc attached to the perimeter of the wall? I'm interested in the proces , and see how is it done. Would be great if you can post some pictures of the proces. Thanks and hope goes well!
D hug
No nails onto the ceiling, with staples in the grooves. The perimeter will have tile butted up to it so i didn't use the edging you'd usually use. I'll take pictures tomorrow
Reply to Pvc ceiling and then tile walls, or tile walls and fit the ceiling after? in the Canada area at TilersForums.com
Finias Coroama
