1animal1
Hi all
I am about to start laying some 600x300x10 tiles, the first 2 of which will have 15mm pipes going through them for the towel rad. The issue i have is that i am using speedfit connections which i have managed to get mostly into the wall, but have a slight protrusion where the chamfered part of the fitting sticks out, therefore i need to use my 18mm ATS bit from the front for the 15mm pipe (bit of margin for error!), then some how chamfer the back of the tile to accept the speedfit fitting - I have bought a further 32mm bit to attack the tile from behind to drill halfway, to hopefully file down - from what i am reading, filing isn't really an option for porcelain.
Can anyone offer any advice as to the way to go with this slight problem
Thanks in advance
Tim
Thanks in advance
Tim
