Need a bit of advice on planning the floor tile layout for my downstairs cloakroom.
The width of the walls run-out by around 10mm as you move from the back wall towards the door way.
Tiles are 600x300 with 3mm spacers. ill be laying them longways, i.e the 600mm edge will run the length of the room from the door to the back wall.
I was thinking to mark out the centre line where the room measures 950-960 wide. Mark this line right down to the back of the room and then work out how best to layout the tiles starting from the centre or close to it so i end up with a decent amout of tile on the last row at each side.
The left side of the room has a good amount of clearance under the plasterboard which i could use to slide the tiles under and cover with skirting once completed.
(no tiles will be going on this wall)
This should mean i only have to deal with runout on the last row on the right hand side. (will be tile the right hand wall)
Lengthways should not be too much of a problem as i can cut the first and last row of tiles to suit.
Would like to know if this sound's like a reasonable plan or if you guys would do something different.
