Discuss Path tiling with Victorian mosaic tile sheets in the Work Wanted for Wall and Floor Tile Fixers area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
We have some Victorian-style mosaic tiles which we need laid on our front path. They are on mesh-backed sheets so no need to lay individual tiles. Each sheet is 30cm x 30cm. There is a concrete base in place, but this has a crack in it so would need to be levelled beforehand. The whole area to be tiled is approx 10m2. We also need black rope-top tiles cemented in along the edges of the path to create a border (these have not been purchased yet).
Look forward to hearing from you if you're interested in the job.
Thanks. I understand from our builders that the crack should be ok as it hasn't changed in the time that we have had the concrete base down (3 years). Hopefully this is correct!
Is anyone interested in this job?
Time's Ran Out
The crack is not going to get any better in the next 50 years your tiles are down. Prepare it properly or your wasting your money.
Dorking path last year :
FEDB489B-41ED-4A28-B771-FAAD3C53A64D.jpeg E7A1FF7A-E82B-49CF-8AC1-537ACC5277FB.jpeg
With rope border.
Time's Ran Out
How do we prepare it properly then?
Your tiler will advise when a site visit is made.
Unless a photo is posted to enable a educated reply.
Always see completed work of any tradesman and if possible references.
Check the forums ‘Find a Tiler’ section for an established member or ask a Trusted Advisor for a recommendation.
Good luck.
Thanks Paul. I have just tried to PM you, but it doesn't seem to work for some reason. Could you PM me, please, and I'll reply with our details?
Thanks.
Reply to Path tiling with Victorian mosaic tile sheets in the Work Wanted for Wall and Floor Tile Fixers area at TilersForums.com
Finias Coroama
