The Wetroom Store - TilersForums.com Sponsor
This official sponsor may provide discounts for members
Discuss Overwhelmed By Whole Concept For Uneven Concrete Sub-base, Laminate Floor in the Floor Advice - Flooring Forum area at TilersForums.com
Sheepdisease
Hello there,
I am looking to have an electric underfloor heating system fitted on an uneven concrete floor for the whole of downstairs.
Downstairs comprises of a hallway, lounge and kitchen. I want to have two thermostats to regulate the temperature of the lounge and kitchen separately, the hallway would be controller by the thermostat in the lounge.
It has been recommended that I use a 160W system.
I have been trying to figure this out for a while but I can't quite figure out what order things need to be done and what products people would truly recommend which are reasonably priced and reliable.
So far I think that you cover the sub-base with some sort of thermal barrier to prevent the heat from escaping through the ground (secured using a flexible adhesive), followed by the heating mat and finally the laminate flooring goes on top without being fixed down to allow expansion and contraction.
Has anyone got any advise for keeping this job low-cost but ensuring reliable results?
At what point would I put down self-levelling compound to even out the differences between heights in areas which used to be divided by brick walls? The height varies by up to 1/2 inch in places.
Mapei Tile Adhesive - Official forum sponsor
whitebeam
Moderator
Reactions
2,920 3
Hertfordshire
You must be logged in to see the message.
hmtiling
Reactions
4,830 33
Isle of Wight
Just Rizzle
  • Thread Starter Thread Starter
  • #9
Sheepdisease
  • #12
Deleted member 5970
Reactions
8,514 63 3
on a yacht somewhere on the essex coast
What member type are you?
Professional Wall and Floor Tiler
Sheepdisease
  • #18
F
Flintstone
  • #21
Deleted member 5970
Reactions
8,514 63 3
Deleted member 5970
Reactions
8,514 63 3
Q
Qwerty
  • #30
Reply to Overwhelmed By Whole Concept For Uneven Concrete Sub-base, Laminate Floor in the Floor Advice - Flooring Forum area at TilersForums.com
uHeat Official Forum Sponsor for Underfloor Heating (Electric and Wet)
Top Bottom
I've Disabled AdBlock
No Thanks
Use TilersForums.com to find Tiling Jobs or your Local Tilers for free. Get tiling tools at the best prices via the forum.
