Discuss Marble floor tiles popped in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
R
Ryan walker
I tiled a floor with 300x600 marble tiles about 8 months ago .
I have just been called and told that some of the tiles have come loose .....
Im trying to assess if i am liable to sort it out at my cost .
The builder plyed over old floor boards and then stuck underfloor heating to the ply and then did a thick layer of self leveling ontop and waited for it to be fully dry for myself to tile . I do remember having to build up the adhesive slightly more one side of the room to keep the floor level.
I used flexible nicobond rapidset adhesive and flexible bal superflex grout.
G
GoneGuy
Movement in subfloor? How thick did you build the adhesive up as some have a maximum thickness
R
Ryan walker
No uncoupling membrane was used as it was the builder that set the floor up i just turned up and had a latexed floor to work with i assumed they would of done there job properly but now a problem has occured i have asked questions how they preped the floor
Dumbo
What thickness ply did he use . Was it glued and screwed. But he shouldn't of done that anyway , my guess latex let go of floor . Also I agree with three previous replies
Time's Ran Out
Wood floor, UFH, self levelling, soft natural stone (marble) covering - no uncoupling membrane = problems!
Who is liable ........ whoever thought that fixing marble to a heated wood floor without an uncoupling membrane.
Sounds the same and sometimes you just have to walk away from jobs if your not happy with the preparation, but really you should have asked your questions of the builder before tiling 8 months ago!
I am assuming you didn’t use a uncoupling mat, did you spread floor and butter back of tile as well as this makes a huge difference as well.
I’m about to do a similar size job, and this kind of experience related & replied to is SO VALUABLE
This forum is literally worth a fortune!
U
Unused Account 1
The subfloor needs to be super secure ,if you tile and someone else did the work ,it comes back to you ,id say the subfloor not secured ,and i like to use ditra,done a few jobs with the ditra heating matt
Reply to Marble floor tiles popped in the Canada area at TilersForums.com
Midland Commercial
