Discuss Mapei with UHeat Ecoboard Queries in the Australia area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
I have ordered Mapei Primer G to prime existing screed, Keraquick to bond eco boards to floor.
Now do I need to prime ecoboards with more Primer G or use SBR? I will the lay UFh cables and pour over some Mapei renovation screed to cover them.
Prime screed with primer G or SBR??
use keraquick to lay slate on...
Am i doing this right?! ( my bank holiday is already ruined!!!)
Don't prime them. They're uncoated.
Good luck screeding those!
Imagine a thin layer of levelling compound dried on a sponge?
That's what you're going to end up with.
I suggest you try not to walk or kneel on the floor as you tile.
Might be a good idea to get a decent sized piece of ply to kneel on as you work?
Impish,
As I understand these are closed cell boards which have a very low permability?
Thus they should be no worse than primed concrete for instance?
But they are very compressible - a thin layer of slc could quite easily break on compression and leave you with lots of small loose fragments and dust.
I've used them before. Once - and never again!
the job went off ok though ;-)
300kPa is roughly 42psi.
Sorry, I just can't see it.
Uheat would want to be pretty careful so if they are quoting a Britishand European standard for their compressive strength!
The celotex product is not equivalent it is (as I understand it) not designed to be tiled directly, but is intended for insulation underneath a heated screed. I am guessing from the question that the uheat stuff is.
Reply to Mapei with UHeat Ecoboard Queries in the Australia area at TilersForums.com
