Can anybody recommend a cutter that will produce very good edge cuts on 10mm very hard porcelain tiles (Peronda from Spain). The cuts will be visable and therefore need to be clean, straight and unchipped. I have several hundred straightish cuts to do and about 20 corner/curve/awkward one's as well.
I have a plunge saw and tried a blade from ATS which they recommended but I have found it performs quite poorly and causes a lot of chipping and tile breakages at the end of cut (face down, face up, slow, fast, single pass, double pass, combination of methods etc).
I have therefore tried a manual cutter, Big Clinker (QEP/Vitrex), which was awful and the breaks were all wavey and uneven and the break lines really poor.
The tiles samples I obtained were cut with an Ishii 620 Pro but again the cuts were fairly poor, although no chips just not straight or even edge.
I therefore purchased a Vitrex 103420 Versatile Power Pro 750w Wet Saw but the quality of the saw is terrible as the spindle wobbles by around 3mm which would result in chipping, therefore that's going back.
Final option I am considering is the Vitrex Versatile Power Pro 900 Bridge Saw, although a bit put off by the quality of Vitrex/QEP stuff but not a lot else within budget.
Anyone know whether this will perform OK or anything else that might do the job OK.
