Discuss Laitance removal - underfloor heating screed in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
kiteboy
Hi all
Just been reading up on the above and it looks like I should have sanded the floor down a bit sooner - no one advised that it should be done after a couple of weeks
Floor has been down a good while now and has a good surface I think - its not crumby at all but hey may as well do a proper job now - I dont want these tiles popping off!
Anyway about to get a tiler to do the floor - but would like to sand it down first and been looking at the costs of the machines
Surface Texture Grinder Str701 110V | Travis Perkins - https://www.travisperkins.co.uk/Surface-Texture-Grinder-Str701-110V/p/522104
Didnt factor that cost in - wow - is this the best thing to do it - only have about 20square meters to do - could try a belt sander - no idea if that would work
Also was planning on putting Bal floor primer as advised by the builder - would you recommend staying with Bal for the adhesive or doesnt matter really
Thanks all
Chris Gibbs
I use a handheld concrete grinder, does the job in seconds ( with a vacuum attachment) a belt sander may work. I use tilemaster primer, its never let me down. oh and use a compatible adhesive for laying the tiles. Tilemaster do a product called Anhyfix especially for anhydrite floors.
J Sid
what is the screed?
how long has it been down?
has the heating been commissioned?
has the screed been tested to see if it's dry?
kiteboy
Had a dig around on my photos - went in on 27th July and it was 50mm depth - dont know exactly what screed it is - but its grey and calcium sulphate - yes underfloor heating is on and linked to thermostat
Not tested as been down 6months! - Cant believe its been that long - you can see why the missus is on my case!
F
Flintstone
Yes it needs sanding and you won't do that with a belt sander after 6 months you need a diamond cup on it.
Reply to Laitance removal - underfloor heating screed in the Canada area at TilersForums.com
Dawz84
