Discuss Kitchen order of finishing off in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
kiteboy
Hi all
Been stuck over christmas with the kitchen install - Howdens cabinets are now all in and plumbing ready to go / waste and water in place
The only thing I haven't done is put the island curved corner posts on and the side panels to the island....this is because I will have to cut those to size and allow for a tile and adhesive which for me is a tiny bit of guess work - so I've held off doing it for now
Oh and we couldn't tile before the kitchen went in as we cant move here so the cabinets had to go in
We are waiting on quartz worktop - not ordered yet though - 30mm stuff
What would you recommend doing next???..... Get the worktop people in to do their thing - then once they are done then tile afterwards - then put on the corner posts and panels
But im guessing the worktop people would want a completed island before they template up things??
Any recommendations would be great - just need a final push on
My main thinking is that if we tile now before the island worktop goes on - we can adjust the island very slightly if needed if something doesn't quite line up
If the worktops go on then we aint moving anything :)
Thanks all
kiteboy
Oh hell no! Is that the best way then?? Seems a waste when we wont ever see the tiles under the island - however can be done no probs i suppose
Bopster
Don’t bother removing island just decide where the island is wanted, temporary fit all posts/panels to island, cut them a few mm oversize and get quartz templated. Then remove and tile floor, now refit posts/panels cutting to desired height, quartz now on and connect sink, fit doors and trims
kiteboy
Island is 2.4 x 0.9m so no big deal if we have to remove nothing is permanently fixed at the moment
I suppose it depend on the tilers preferences too maybe? - so will contact a couple to get a few quotes and check their availability too
Thanks Bopster that sounds fine too thanks all
widler
Remove the island, or tile around it if you want to make life hard, it’s easy enough to do, but much harder work that removing a few units
Bill
cutting twice - creating work is not productive.
J Sid
just tile round it, lift it up if need and tile under end panels. To much hassle taking it right out,
Bill
5 mins to drag it in and out or an extra hour of cuts dust wet tiles lining them up levels if needed and if the island needs moving or changing the floor is good to when you tile it first
Simples.
Reply to Kitchen order of finishing off in the Canada area at TilersForums.com
Dawz84
