Discuss How to raise this sub floor? in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Sam96
Can anyone suggest the best way to lift this concrete sub floor so that when it is tiled it can be level with the wood? Previously was tiled over tile which is why the level is 2 tiles de
I am thinking cement boards?
also Can cement boards be stuck Directly over this concrete sub floor even if it has old adhesive? the adhesive is solid or does it need to be removed?
thanks
youll be lucky to do any thing every merchant i know is shut. but i would use foam boards like wedie or jacker or similar
faceman
sorry to hijack this thread but I need to something similar over an anhydrite screed with ufh. I assumed insulation boards would be no use because of ufh. Would anybody recommend hardi backer adhesived down. There is very little info on this, I may even be the first to face this problem. It's only 180m2.
Boggs
How much have you got to raise by?
You could level the floor with this.
Reply to How to raise this sub floor? in the Canada area at TilersForums.com
Finias Coroama
