Discuss Hardibacker Or Orbry? in the Australia area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Lakey
Afternoon
I know this is a similar thread to one already started however slightly different so warrants a new thread?!
I have a 'Sun Room' floor to tile in a 1st floor extension.
The floor is softwood floorboards with no obvious deflection & the tiles are 900mm plank wood effect porcelains.
I recommended 6mm Hardibacker stuck down with rapid flexi with scrim tape joints & screwed when dry.
The customer has bought 6mm Orbry board......?
I questioned whether this would be rigid/stable enough as an overboarding method especially with such long narrow tiles.
What are your opinions/recommendations?
Thanks in advance
I
Ian
Provided the deflection is as you say, then yes, they'll be fine to use. Fit as per the HB with adhesive and screws.
Spare Tool
Christ, thats a turn up..so your supposed to trowel adhesive, bed hardibacker and leave to dry before screwing it down..well that's a new one on me, just checked website and can't find that snippet of information..like a link to that :)
Well the way I'd look at, if there was no instruction in the installation notes is this, if you're screwing down 6mm Hardie into wet adhesive it can deform.
We know the idea is for the adhesive to give u a flat surface for the Hardie,
So if u don't wait for it to dry and screw it down, u stand the chance of not getting a flat surface.
After all, that's one of the objectives of using it, is t it?
widler
Just the way I do it, to me it squashes down the addy and fills the voids properly , if it deforms the boards that bad your floor is buggered and should be straightened with a bit of slc .
I don't expect Many to agree with me on here ,I've stopped more threads than Mike Tyson stopped fighters, although I did get told to do it like that on here years ago, but folk change there mind like the wind on here and tend to forget, I love it on here :tearsofjoy:
widler
The idea of the addy is to fill voids under the floor, not straighten it, folk make things up as they go along on here , what do you do, dot and dab the bloody thinks, we are making the floor a surface to tile onto not straighten like drylining, if it needs straightening, you slc it, **** , though, I'm a plasterer, I should be drylining the floor, I'd be good at that
What are u talking about! That's nonsense!
U really do get ur knickers in a twist on here lately Craig!
Not the person I remember!
If u have a straight board and u fill the voids with adhesive you're straightening the floor!
By the very words 'FILL THE VOIDS!' You're straightening the floor!
A void is a dip in the floor is it not!
So if u fill that void, u've straightened it!
I never once mentioned LEVEL did I!
So by that rationale, u lay your Hardie in wet SLC do u!
And if u read my post more carefully, it says 'the way I LOOK AT IT'
It wasn't a definitive answer!
p4ulo
I would use either, both will achieve the same.
Hardie should be screwed when adhesive is wet. The screws hold the board down, the adhesive fills the voids, they both work together and it should be done wet to squeeze the adhesive down tight, otherwise if you were Hardie-ing over uneven boards, you'd have to slc before laying hardie? and you wouldn't screw through slc would you? Also, doing it dry stand the risk of de-laminating the adhesive / hardie bond, surely?
Reply to Hardibacker Or Orbry? in the Australia area at TilersForums.com
Matthew77
