RandyC
So I've got a kitchen dining room which I want to tile all the way through. The kitchen is concrete base and the dining room is floor boards.
I plan on putting 6mm HardiBacker Board on the floorboards, but that will raise up the dining room by 6mm above the kitchen base. The concrete is sound but do I need to use SLC on the kitchen to raise it to the same level, or I've seen people talk about adhesive beds can be different thicknesses depending on the trowel so could that be an option as it's 'only' 6mm? The kitchen area is around 18sqm.
Also is this flexible adhesive suitable? There seems to be no end available and I've read that SPF is ideal for HardiBacker tiling, which this seems to be:
Thanks!
Mapei Mapeker Rapid Set Flexible Tile Adhesive Grey - 20kg | Wickes.co.uk
www.wickes.co.uk
Thanks!
