Discuss Grout line size 2mm or 3mm in the DIY Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Hi All, about to tile my bathroom walls with 600mm x 150mm tiles and not sure whether to use 2mm or 3mm grout lines also using the same tiles on the floor what would the grout line size normally be with the floor tile, Thanks in advance.
WetSaw
If the tiles are rectified or good size wise I'd use 2mm with stacked layout. Brick bond you'll need to make sure the tiles aren't bowed, in which case you may need a bigger grout gap.
Thanks, pdc think I will go safe with 3mm on walls and match 3mm on floor as I think tiles have slight bowing , might give me a bit more room for errors.
WetSaw
Put a couple face to face and see what they're like. Levelling clips can help reduce the bowing.
Reply to Grout line size 2mm or 3mm in the DIY Tiling Forum area at TilersForums.com
hoponbaby
