Discuss First time tiling with marble. Advice please in the America area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Hello
It's Hugo here. I did have an account on here before but can't seem to find it, so I have re registered.
It will the first time tiling with marble.
The customer is looking at 600x600 on the floor and 600 x 300 on the walls.
There is a load of prep work to do first I know and I'll be asking about that too. I have some ideas here.
These will be laid with a gap using tile spacers.
I have done a fair bit of tiling with ceramic and porcelain but I feel marble might be less forgiving if I get it wrong
What are you concerned about?
Essentially the differences between this and what I have edone before.
1 the floor tiles are 600 x 600. I've never laid tiles that size before.
2 marble is not something I've worked with before. What adhesive should I use, should I seal the tiles before they go down, what size trowel should I use or do I go flat bed etc
Many thanks
Kevbos
Hello
Tell the customer , you haven't worked with marble before , and you have no idea what you are doing
bsc ceramics
Use a good bagged flexibal adhisive in white something like ardex X7W
and just take your time. A trowel with a 12m notch. Make sure you get the prep
right and your be fine... Are you a tiler?
Thanks for your replies.
To answer other questions I have tiled countless bathrooms and have several satisfied customers and no unsatisfied ones.
So as being a tiler is concerned I work across a number of trades. Right now I'm underpinning my house.
I know I will need a wet cutter and I was going to buy a vitreous gantry type cutter. They seem fairly reasonable in price. I've been thinking of getting one anyway.
I've also been thinking of those self levelling tools you can get. I've never used the, before so I thought I'd get some. What does everyone here use please?
The bathroom isn't huge. It's app 6 x 8 feet in total. So about 12 600mm square tiles on the floor in total.
The wall tiles are 600 x 300 so I want to try to set them so I get grout lines running running from floor to wall
Preparation
The floor needs to be channeled for plumbing etc. It's a solid floor. So after the channels have been dug and the plumber has been I will fill the channels and level it using a self levelling compound, if needed.
The walls are a nightmare. If I board it out I will lose precious space. So I am going to have to level the walls with tike adhesive etc. I'm going to use battens for this I think or build up verticals using rapid set and use those as guides etc. I have some adhesive left over from previous jobs that is in date.
The old tiles having removed much of the final skim will help. The render will provide an excellent key.
Then I will need to waterproof the solid wall behind the shower and there will e wediboard going up on the adjoining stud wall and they will be sealed together using waterproof tape etc.
Good white bagged adhesive. I invariably use Weber but if the Ardex is better I can use that.
Trowel size. I was going to use something like a 12mm notched or similar on the walls. The floor however I was wondering if I should go bigger, or do I back butter the tiles using the same 12mm ?
Kevbos
Preparation
Lol you seem to jack of all trades !!underpinning a house properly also requires skill
The underpinning, along with all my work on this house is being controlled by LABC.
I look at everything as a process. I am a degree qualified engineer having worked for several years in manufacturing. Whilst I don't claim to have in depth knowledge about very much I have learned that a combination of knowledge, aptitude and skills brought on to many jobs can achieve the correct result.
If the skills are lacking one can do a certain amount to reduce the skill level needed for the job. There are loads of tools out there that aim to do exactly that.
In the case of the marble tiling I know that marble tiles will be less forgiving than ceramic or porcelain, so from the point of process I need to be ontop of my game.
Hi Hugo.
You will be adding a lot of weight to those walls , the substrate needs to be suitable to take the weight. A suitable backer board will be required IMHO.
Thanks Dave, and long time no see!
Three of the walls are solid concrete block. The 4th is a stud wall that I was going to use wedi board and plasterboard.
From what you're saying do I use hardbacker on all the walls with mechanical fixing and waterproof the shower area, or just the stud wall.
Also will wediboard support the tiles, or do I use hardibacker and then waterproof?
Dave
What is covering the block walls ?
Reply to First time tiling with marble. Advice please in the America area at TilersForums.com
Midland Commercial
