- Reaction score
- 5
Hi all,
I've been fortunate to get a fair few 30-40m2 downstairs flooring in varying new builds (private work). So kitchen hall utility downstairs loo etc.
Each time the customer wants a continuous floor I.e. no door trims.
I use a multi tool to cut the bottom of the archies and slide the tile under.
The problem I've been having is the skirting boards (and walls) are never parallel in two adjoining rooms and in effect you need a horse shoe shaped tile to get the tile neat to the skirting boards on both sides of a door way.
I've tried different methods to get over this problem and outlined the problems with each below.
1 - take all the skirting boards off before starting. Problem with this method is it's a nice new white painted new build and the skirts are usually siliconed to the concrete floor. So when finished and stuck back on it never looks as good as before I started.
2. Set out the tiles in such a way that the horse shoe cuts have a really thin bit somewhere, notify the customer of the issue and then do a cut in the horseshoe in an inconspicuous place and stick down without a grout line, sort of masking the issue. Problem here is it drives me mad and I can't stop looking at It afterwards.
3. Not tried this yet because customers never want them, but maybe
put expansion gaps in the doors. I beliebe this is the 'proper' way due to varying room temperatures etc and size of floor, so get customers to sign off they've told me to do it that way...
What do you guys do? Have I not thought of something ...
Thanks,
FD
Thanks,
FD
