Discuss Efflorescence in new Grout. in the Tiling Advice | Tile Forum area at TilersForums. USA and UK Tiling Forum
MPE
Just tiled a hallway and used Dark Grey grout which developed horrendous patchy efflorvescence. Any ideas? I contacted the manufacturer NX adhesives, but no reply.
Bond
Efflorescence should not be a significant factor in Modern cement based grouts, What type of substrate have you tiled over and any pictures showing the extent of the problem.
OP
MPE
[automerge]1602529087[/automerge]
[automerge]1602529219[/automerge]
The substrate was concrete floor in a hallway that had been down for 30 years.
[automerge]1602529313[/automerge]
It was done in a very hardwater area though that suffers from limescale a lot.
Bond
Difficult to tell from the picture, efflorescence normally forms crystal like structures from moisture that has evaporated from the surface. May well be lime bloom as you say it’s a hard water area. In any case you should be able to obtain a chemical product to deal with it.
Reply to Efflorescence in new Grout. in the Tiling Advice | Tile Forum area at TilersForums.com
mmcdon47
I've Disabled AdBlock
