Discuss Doing large bathroom with Gazzini porceline 12" x24", having trouble cutting this tile. Long and short ways. Using Rubi Viper in the DIY Tiling Forum area at TilersForums. USA and UK Tiling Forum
Straight cuts long ways and cross cuts. Some very close to edge of tile on long cuts.L cuts or straight
Using a target wet saw and also a Chicago electric wet saw( Harbor Freight)Straight cuts long ways and cross cuts. Some very close to edge of tile on long cuts.
Seems like blade is getting hot and moving. Using water of course.Using a target wet saw and also a Chicago electric wet saw( Harbor Freight)
Never had trouble cutting porcelain before this.
Are your tables square to your blade? Is your blade spinning the right way? Also if your blade is rounded on one side from easing edges or naughty blade abuse it’s going to push one way then the back of the blade will align with the kerf and try to push it back or take more material. Get a framing square and a dressing stone and clean your arbor and backer plates. Or just buy a new blade.
Table and blade are square to each other. Brand new Rubi Viper 10" blade.Are your tables square to your blade? Is your blade spinning the right way? Also if your blade is rounded on one side from easing edges or naughty blade abuse it’s going to push one way then the back of the blade will align with the kerf and try to push it back or take more material. Get a framing square and a dressing stone and clean your arbor and backer plates. Or just buy a new blade.
I changed direction of blade and dressed the blade, seems to work better. ThanksAre your tables square to your blade? Is your blade spinning the right way? Also if your blade is rounded on one side from easing edges or naughty blade abuse it’s going to push one way then the back of the blade will align with the kerf and try to push it back or take more material. Get a framing square and a dressing stone and clean your arbor and backer plates. Or just buy a new blade.
Get your self a montolit 👍🏼🚀💥Doing large bathroom with Gazzini porceline 12" x24", having trouble cutting this tile. Long and short ways. Using Rubi Viper 10" on two different saws.
Blade seems to bend when cutting . Never had trouble cutting porceline tile. Thanks Ron
Reply to Doing large bathroom with Gazzini porceline 12" x24", having trouble cutting this tile. Long and short ways. Using Rubi Viper in the DIY Tiling Forum area at TilersForums.com
