Hi, First time poster, usually can find answers through previous posts, but i need help on this one. I have to tile approx 40sqm of a ground floor with travertine tiles, i have ordered mapei marble and stone cement https://www.tilersforums.com/forums/tile-adhesive/ on the basis that i had a cement screed (checked utility room) unfortionately after removing the rest of the laminate flooring i have found something which i suspect is the dreaded magnesite topping. Beneath is a discription of what i found:
A smooth almost polished yellow to brown screed at around 20mm deep
It had damp areas, my house was built in the 1950's and therefore i believe there is no dpm, also the floor was covered with a polythene membrane then foam then laminate so it would have trapped moisture.
The damp patches i could scratch lines out with my fingernails
The solid a bolster was needed to chip it
small fragments would disintegrate between two fingers but not a dust/sand like substance
I took a blow torch to a sample and it did not catch fire
The edges, only the thinnest possible part would burn the colour of a lit cigarette, not a lot of smoke, not much heat retention and it had a faint smell of rubber.
finally i took a volt meter (don't have damp reader) and tested the floor, on contact + - it would go to 2 oclock max - half an hour dry spots (12hour clock face)
Nails rusted and internal beads rusted to approx 4 inches up, not everyone though.
I made the above points as through reading previous posts these were the questions asked. One of my main hopes about the possibility of it not being magnesite is that i have read that it is a cork like substance and a good underlay. My floor is hard and polished and smooth, if snapped in half it does have slight bubbles but nothing extreme, same as mortar.
Your opinions would be really appreciated, i dont want to rush ahead and rip it up if it is an alternative topping that is acceptable as a bond.
