uHeat Official Forum Sponsor for Underfloor Heating (Electric and Wet)
This official sponsor may provide discounts for members
Discuss delaminated plaster on wall in the Floor Advice - Flooring Forum area at TilersForums.com
The Wetroom Store - TilersForums.com Sponsor
Sean Kelly
Supporter
Reactions
628 1
Ruislip
I was only supposed to remove bottom 2 rows of tiles but i found that the skimmed plaster has debonded from the wall. could i just prime and use a skim of rapid over the top....then tile when dry? or do i get a plasterer in?
Sean Kelly
Supporter
Reactions
628 1
Ruislip
  • Thread Starter Thread Starter
  • #3
Thanks Julian
on closer inspection and a bit of scraping is that hardwall beneith? I just need to be armed with suggesions on what we do next. cheers14944923966601918626650.jpg
JulianSidney
Reactions
8,489 63 3
on a yacht somewhere on the essex coast
What member type are you?
Professional Wall and Floor Tiler
treat as bonding and not tile it I believe. If tile weight is ok I'd say replaster and come back when dry to tile.
normally just over board but obviously you can't looking at picks.
Dan
Admin
Staff member
Reactions
5,789 31
Staffordshire, UK
DIY Wall and Floor Tiler
If you're in a rush to get the shower back perhaps try knock a little bit back see where it ends and see if you get enough space to overboard with thin plasterboard or whatever.
Sean Kelly
Supporter
Reactions
628 1
Ruislip
  • #7
cheers Dan we are tight on space as it is. got to go for bumpy whites or else the screen wont fit!
Dan
Admin
Staff member
Reactions
5,789 31
Staffordshire, UK
The things we do to get the job done eh
Sean Kelly
Supporter
Reactions
628 1
Ruislip
  • #9
Trying to get a plasterer in is a nightmare. I'm now looking at Youtube on how to plaster a wall. The things we do to get the job done!
Q
Qwerty
Hack off to brick/ block and then board it to fit flush with the existing walls...... like this I did a couple of weeks ago........
20170424_090817.jpg 20170424_101949.jpg 20170424_101955.jpg 20170424_113255.jpg 20170425_145826.jpg
Sean Kelly
Supporter
Reactions
628 1
Ruislip
  • #13
Just an update.
Got myself a bottle of PVA, plastering hawk and some multi finish. Will watch a few plastering videos and then tackle it on Monday. Got to do it this way because the shower tray is rebated into the wall so much that the new screen barely fits on the old tray. The shower screen brackets have to go in first then I tile upto them. I know it's not the right way but the alternative is to smash out the old tray.
I'm doing the plastering for free plus the cost of materials. Customer happy and I get to practice plastering!
Sean Kelly
Supporter
Reactions
628 1
Ruislip
  • #15
How did you get on with your plastering?
Not as easy to do like the pro plasterers!!
3 coats of PVA and 2 skim coats.
I tried to practice polishing but plaster was drying fast. Got it good enough for tiling over. 2.5 hours from start to driving away. Pretty pleased with the result.
Reply to delaminated plaster on wall in the Floor Advice - Flooring Forum area at TilersForums.com
Click here to support the forum/remove ads
TileFix Direct
Use TilersForums.com to find Tiling Jobs or your Local Tilers for free. Get tiling tools at the best prices via the forum.
