Discuss Cuts on orbry tray in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Oldshore
Hi. I have just bought a orbry 30mm wetroom tray. 1200x900. It has a linear drain. I am looking for advice on the cuts as it has a 2degree fall but the sellers reckon I need to make a mitre from each corner to each corner of the drain? I have not decided on 300x300 or 400x400 so any advice would be good.
Thanks David
Q
Qwerty
The sellers are correct. 'Envelope' cuts from corners of drain to corners of tray would not be affected by tile size as it is all about how you want them to be set out.
Oldshore
Hi. Ok that's what I thought but wanted some professional reassurance. Thanks again.D
Reply to Cuts on orbry tray in the Canada area at TilersForums.com
Matthew77
