Discuss Can I tile onto well stuck vinyl planks? in the Floor Advice - Flooring Forum area at TilersForums.com
The Wetroom Store - TilersForums.com Sponsor
This official sponsor may provide discounts for members
Glynn
Reactions
197 1
LEYLAND
It's not a case of being controversial it's having complete faith in the products that Tilemaster produce and good work practices. I was on the tools once and had to over-come issues that are not covered in the "Standards" but still had to give the customer a guarrantee. Now part of my job role is to test products till they break (not just Tilemasters either) so I can then help you tilers on the tools with real world information that I hope will make your work a bit easier but still give you confidence in the products, work practices and materials you are using. BS5385 gives you very basic standards to work with but for me it does not address the real world a tiler has to work in threrfore if the information from myself seems controvestial be assured it is not coming from "Glynn's world of tiling", it has been tested, discussed and debated within Tilemaster and the whole technical department are of the same opinions and will stand by the information we put out. There have been several times you forum members have contacted us direct for help in resolving a problem you have on site because the "Standards" don't cover your problem for you. Have any of you had an issue with the advice we gave you? I doubt it, otherwise it would have been posted here. If I say it, then it is on behalf of Tilemaster Adhesives.
JulianSidney
Reactions
8,489 63 3
on a yacht somewhere on the essex coast
What member type are you?
Professional Wall and Floor Tiler
Glynn, yes you products are good so I've heard, not tried any myself.
my comment was tongue in cheek :rolleyes:
my issue would be with how well the flooring which is to be covered with tiles is fixed not if there is a product which can stick to it.
not taking it up quite frankly, is just lazy and bad practice
Glynn
Reactions
197 1
LEYLAND
Morning Julian. I don't agree with "lazy". if there is a substrate that meets BS5385 with flat, strong, "firmley bonded" which is what I originally said, and strong enough to support the weight of the tiling installaion, why not use it? Most of these vinyls are stuck down so well it take a lot of work to remove them. Would you remove a tiled floor if it was firmley bonded if you didn't need to? probably not. Why make work for yourself if there are products out there that will make your days work easier but still give you the guarantees you need for your customers use them. It is totally the tilers choice, they are the ones on site and have to decide "do I remove it or can I use it". You have heard how good Tilemaster products are, I hope one day you will give us a try, and our technical support as well.
Waluigi
I’d still remove in this instance, mainly because I have no idea how the floor was latexed. I remove a fair amount of LVT floors and it’s not uncommon for the SLC to come up with the tiles.
I completely get that the adhesive is able to be bonded to the Vinyl though and I have a special place in my heart for Tilemaster :D
Happy Thursday everyone.
Waluigi
Besides, we’ll find out later today that the floor in question is LVT click :D
Reply to Can I tile onto well stuck vinyl planks? in the Floor Advice - Flooring Forum area at TilersForums.com
Click here to support the forum/remove ads
TileFix Direct
Use TilersForums.com to find Tiling Jobs or your Local Tilers for free. Get tiling tools at the best prices via the forum.
