- Reaction score
- 0
Can anyone recommend the best brick acid to use to remove efflorescence and stain8ng on exterior porcelain patio paving tiles?
Discuss Brick acid advice in the The Welcome Forum area at TilersForums. USA and UK Tiling Forum
Great, thanks for the advice.Brick acid is just dilute hydrochloric acid normally at 15% although you can buy up to 25%. You can buy it cheaper as an unbranded product on Amazon
Ok, thanks for the help.Try ltp cement grout and salt remover.
If its a highly polymer modified grout then you may need a something to break that polymer down so LTP Solvex will do that
Thanks for reply.Check out Lithofin products
Reply to Brick acid advice in the The Welcome Forum area at TilersForums.com
