Discuss BEST FLEXIBLE FLOOR GROUT (2mm joints) Floating Floor! in the Tile Adhesive area at TilersForums.com
U
Unregistered
Hello,
Was wondering what is the best flexible grout for a polished porcelain floor with 2mm joints. (Tiled on a floating floor)
Was advised by tile shop to use Mapei Ultra colour plus, adding flexible primer?? But grout has cracked, well more sort of come away from the edges.
Tiler happy to come back and put right but talking of using epoxy grout? Wondred if that sounded correct or not?
As an absolute no nothing about tiling lady, I have spent ages trawling through the internet and it would appear that a flexible adhesive with no additive would be better? Read Bal superflex (not wide joint) sounded good? I am of course ready to be corrected:)
OP
Deleted member 9966
personally I think you're going to struggle with the floating floor and the grout. it's the floating floor that is causing the grout to crack more than likely. so no matter how flexible the grout is, it will still eventually fail as the grout is not rubberised to take the floor deviating in different directions. unless of course your floating floor is more rigid than it seems, you will struggle to keep the grout intact. many professional tilers do not like floating floors because essentially you are not tiling on to anything rigid. As soon as you walk over the floor, you're adding movement to it, and if it's not rigid to start with, the tiles will go with the movement and become detached in the worst cases.
do you know how your floating floor was constructed?
Upvote 0
OP
Stewart
To be honest, your tiler should have warned you about the dangers of tiling on a floating floor. Most tilers on the forum would recommend not to tile, as a floating floor isn't suitable to be tiled on, and more than likely, all types of grout are going come loose from the joints due to too much movement in the floor.
Upvote 0
OP
U
Unregistered
Hi All again,
Didn't know how to answer back - Sorry first time post!
Tiler did actually warn us beforehand, but spent a long time making floor as rigid as poss (unsure exactly what he did - sorry)
Am aware that this may be an ongoing problem with the grout if there is movement but think its woth one more go to see - Any suggestions as to which grout would be best.
Grout appears to be coming away from the edges, tiler mentioned as they were sealed porcelain, grout may not have bonded to edges of tile? therefore he suggests Epoxy - Sounds very messy from what I've read.
I assume no one thinks its the additive that was mixed with the Mapei Ultracolour that was the problem?
Your advice is invaluable, what a great forum - Thanks for your time
Upvote 0
OP
Gazzer
I really dont think Epoxy grout is the way to go.
I would be thinking that if the Mapei grout has failed then there was either and error in the application or there is too much movement in the floor.
The most flexible grout I have ever used was Bal Wide Joint with GT1 admix.
Upvote 0
OP
simon1
Hello,
Ultra color plus grout should not have an additive added to it as its already flexible.
try the Bal non flexi with Bal GT1
Upvote 0
OP
peckers
As a few others have mentioned use Bal standard grout and use bal gt1 additive! mix the bal gt1 50/50 with water and mix this togeather and then add your grout! you will have to measure the grout powder and the gt1 and the water exactly if you have to mix more then one batch so as the colours are identical! There maybe other makes you could use but I worked on a floor which was tiled by another tiler which was floating and they had the same issues! 3 times the tiler re-grouted it and it cracked everytime after about 6 weeks! I used the bal with the gt1 and it has been there for 9 months and so far no cracks! but there is no guarantee as the prep work was all wroung on this particular job!
I contacted bal before i did this and they advised using the gt1 at a 50/50 mix and this is the most flexible method that they do! They also advise NOT to mix there gt1 with grouts that are already flexible as the polymers are different.
There are probably other makes you could use but this one worked for me (so far) Its worth giving it a try to see if it will work.
Upvote 0
Reply to BEST FLEXIBLE FLOOR GROUT (2mm joints) Floating Floor! in the Tile Adhesive area at TilersForums.com
Similar threads
  • Question
Not long ago I had the existing water damaged downstairs bathroom floor replaced with a whole new chipboard floating floor – this was before considering tiling, so I realise it would have been better to fix the floor but too late now. Having later decided to tile, the tile supplier suggested...
  • Question
My tiled bathroom floor is new but I have moisture seemingly seeping up through the grouting in some places. The affected grouting has taken on an orange colour with crystallised minerals of some kind in it. The floor is wooden floorboards, with some kind of baseboard on top (not sure of the...
  • Question
Hi I am posting in the hope that someone may be willing to offer me some advice about floor tiles in a new build property. The house has a screed floor with under-floor heating. I need to have about 100 sq metres tiled downstairs (hall, kitchen, utility, living room). The tile will be...
  • Question
Hi all I’m a homeowner and have just had my bathroom floor tiled and am requesting your opinion please as to whether you think that this is a good job? Some of the tiles appear uneven and the grout joints differ so I’m guessing spacers weren’t used. In fact in some joints it looks like you won’t...
  • Question
The grout keeps coming out on my new shower floor and it is discolouring on the built in seat the grout (the photo below doesn't show the discolouring as it was taken when it was newly finished but the grout on top of the seat has turned an orangey colour). The grout on the shower floor has been...
Gazzawade
Tiling Courses
Workwear for Tradesmen
Mapei Tile Adhesive and Grout
uHeat
The Wetroom Store for all Wetroom Installations
Nicobond Tile Adhesives and Grout
Latest 10
Thanks for visiting TilersForums.com, formerly known as TilersForums.co.uk.
Search Forum
