MAK_Tiling
- Reaction score
- 14
Bathrrom getting ripoed out everything except the bath with two internal walls and two external.
Plan is to rip out old tiles,take wallpaper off plus any plaster left behind it and board all walls with marmox multiboards and seal joints on boards around bath area with their waterproof tape.
What size boards would you recomend since i dont know what the studs are centred at? E.g marmox 10mm centred every 300mm and 12.5mm is at 400mm.is this a big deal or should i have studs already bought incase of need to sister studs together to match the size but also to get the studs plumb and flat as possible??? =S
Solid walls dot and dab plus mechanical fixings.the floor looks like some sort of fake tiles maybe stuck down with floorboards underneath. Whats best to use on floor in this situation marmox or a cement board or a decoupling membrane like dural yellow one for ease of mind of no cracks tranfering through??.
Bathroom.wals 15sqm and floor about 5 and tiles are ceramic wall and floor
Walss 25 x 50cm
Floor - 45 x 45cm
Looking forward to hearing on any advice or tips i should know or methods i should consider. Many thanks
Walss 25 x 50cm
Floor - 45 x 45cm
