Hi all, new member and my first post...
I’m doing a full bathroom refurb. I last did it about 12yrs ago and that job lasted with no leaks or lifting or cracked tiles etc. But from some up to date research, previous job was all wrong. 6mm plywood screwed down on t&g floor boards, sealed with pva then tiled over with tubbed unibond wooden floor stuff. But as said that job has lasted 12yrs.
Change of decor has forced this refurb...
Anyway back to the job. I’ve screwed down 12mm WBP, I ordered external WBP, but to my horror and only noticed when plywood was fitted and screwed, they delivered internal grade stuff. The floor is now very solid with no creaks or movement and I have 6mm backer boards to fit over the plywood.
Can I stick with the plywood that’s now fitted?
How do I fit the backer board? Is 25mm turbo gold scews enough without using https://www.tilersforums.com/forums/tile-adhesive/. My fear with https://www.tilersforums.com/forums/tile-adhesive/ on the plywood is that it is not external grade stuff.
If https://www.tilersforums.com/forums/tile-adhesive/ is 100% needed as a thin set between plywood and backer board, do I need to seal/prime the plywood.
What tape do I use on the backer board joints?
Thanks...
Thanks...
