Discuss Any fix for this limestone? in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Spare Tool
Builder on the job I'm on has blobbed these limestone on two window cills, not sure what adhesive was used but he was using grey rapidest on a bathroom so presume it would be that.. They were fitted six months ago and never been sealed, they have no tiles left so any ideas to sort besides rippling em out?
Its not really my problem but said I'd ask for her..
C
Concrete guy
I doubt after 6 months you'll be able to remove the adhesive stains.
If this is a case of give it a go or rip them out, the alternative is to stain the entire stone with linseed oil or similar. It may disguise the stains.
It's probably worth a shot before taking a hammer to them.
Spare Tool
Thanks Alan, sounds worth a go.. When you say or similar, anything specific?
Builders long gone Julian and won't be coming back, just thought I'd ask and see if there were any suggestions :)
J Sid
linseed oil can be bought at most hardware shops Andy. You can dilute it down with some white sports so it's not so thick and penetrates easier. adding extra coats should darken it up.
Tile Shop
Wouldn't advise oil personally. Yes it would deepen the colour of the limestone but it will also highlight the spots so not fixing the problem, just darkening the whole lot.
LTP have just produced a new product. It was aimed at landscapers who quite often spot-fix stone with sand and cement and end up with the same problem. From what I've heard it sounds like some kind of voodoo magic but the director assures me it will penetrate the surface and remove the spot marks. Its the "Cement, Grout and Salt Remover". Also suitable for removing grout stains and haze from all forms of un-polished stone.
LTP Cement Grout & Salt Residue Remover - https://www.ltp-online.co.uk/prod/ltp-cement-grout-and-salt-residue-remover
If it does work, could be a good little problem solver several types of issue.
I kept getting salt residue on my white limestone.
The last time I scrapped it off I tried sealing it with coconut oil.
It darkened it slightly but haven't had any salt deposits for over a year.
It is lightening up again and will probably need doing again shortly.
Worth a try.
Reply to Any fix for this limestone? in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
hoponbaby
