Deleted member 1779
As we close out for Christmas 2011 and the end of the year
I thought it worth posting up some information introducing
new forum readers to our No1 best seller the "bathroom fitters kit".
This simple solution has a combination of the service pipe sizes for a bathroom (example: Radiators, Shower Head, Waste, 22mm Bath pipe) and also a selection of 6mm and 8mm cores to tackle the red rawl plugs and brown rawl plugs for fitting fixures and fittings. (example: loo roll holder, mirror, shower screen, robe hook, soap dish, cabinets).
The service pipe cores can also be used to open up (widen) holes to suit ANY size that you may need in a tile.
For those of you new to the Tilers Forums here is the best selling tile drilling solution for very hard tiles:
At £49.99 (£41.66 plus VAT) the drills work out
at an incredible £5.95 each plus VAT !
Including 20% VAT
You simply cant buy them in the shops that cheap. And the reason is that 365-Drills are the UK manufacturer of them.
Made in a UK factory.
Each pack has a FREE anti-slip guide plate so that you can drill without skating on the tiles.
You do not have to spend extra cash on complicated and expensive clamps which can fall off the wall.
We even offer a simple explaination of how to use water to cool by using a wet sponge
Why waste £30 or £40 of your money on water cooling systems which add cost and is an additional cumbersome step?
Yes we sell the sponges (if you want them) for £1.75 but we make it very clear you can utilise your own.
Hold ANY water filled sponge UNDER the rotating core to cool and to catch dust.
A sponge soaked in water eliminates dust exposure for the installer and increases the lifespan of the holesaw by cooling the drilling operation leading in turn to faster drilling.
Using a dedicated drilling sponge saves contaminating your clean sponges with grit, dirt and diamonds.
Lightweight easy to use equipment gets you fast access into awkward areas.
Drilling to milimeter perfection on those expensive porcelain tiles.
Wont break them too!
Accesories and fittings are fitted with perfection on any tile job.
Including 20% VAT
