thegwads
pulling up a tiled floor in en suite that has been laid with what looks like tubbed flexi tile on wooden floor adhesive. there has been a leak, and on pulling up the tiles it is ripping chunks out of the chip board. 1st floor flat in big london posh appartment, so under chipboard is polystyrene insulation then concrete floor. chipboard is 25mm i would say, and 18mm of poly insulation.
i need to put a new floor in, what is your advice.
i thought, rip out all bad stuff,, i.e all the chipboard, then grip fill some 3 x 2 cls stud timber to the concrete base, at 150mm or 300mm intervals, and lay 15mm ply or 18mm or whatever it takes to get back to the original level.
does this sound a plan, or does someone else have a quicker idea which will save time?
cheers
cheers
