Gary
Due to customer changing from bath panel to wanting tiles around bath need some advice on how to make it look best. I'll attach some photos and any advice on what looks best would be great thanks
Discuss Advice for tiling around end of bath panel in the DIY Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
@pdc - it’s to follow the bond from the side wall - it’s because customer changed mind after setting out!!
It should be two L cutsIt's to run in line with the tiles at the either side level to top of the bath. Would you say have the tiles in full across the front of the bath? It would just mean there would be a small cutting in the top corners if you know what I mean?
Would you post a photo when it's done please? I'm new to this myself so I'd be genuinely interested to see how it looks,Yeah the L cuts Is the other option . Just wasn't sure how it would look and marry up against the sides. It's not fixed so can be changed. Thanks for the advice
Reply to Advice for tiling around end of bath panel in the DIY Tiling Forum area at TilersForums.com
