Discuss 6mm Marble Drill Needed in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Alzak
Hi all,
Need 6mm drill to hang some shelves in my bathroom can you recommend something that would not damage tiles ?
Many Thanks,
Pro Tiler Tools
Hi all,
Many Thanks,
Morning,
Thanks for the recommendation Plan Tec :grinning:
Would you prefer a wet or dry hole cutter Alzak? (both listed below)
Wet Eco: Economy Hole Drill 6mm (2 Pack) 756 | Buy Economy Tile Hole Cutters Online from Pro Tiler Tools - https://www.*******************/economy-tile-hole-cutters/467/economy-hole-drill-6mm-2-pack-756
Wet Professional: Marcrist PG 850 6mm Porcelain Drill 490.001.006 | Buy Marcrist PG850 Tile Hole Cutters Online from Pro Tiler Tools - https://www.*******************/marcrist-pg850-tile-hole-cutters/24/marcrist-pg-850-6mm-porcelain-drill-490001006 plus you also need: Marcrist PG 850 HEAVY DUTY Water Swivel 490.003.038 | Buy Marcrist PG850 Tile Hole Cutters Online from Pro Tiler Tools - https://www.*******************/marcrist-pg850-tile-hole-cutters/33900/marcrist-pg-850-heavy-duty-water-swivel-490003038-- and some form of water pressure bottle.
Dry m14: Pro Tiler Dry M14 Cut Diamond Hole Cutter 6mm PTTMD006 | Buy Pro Tiler Diamond Hole Cutters (Dry Cut) M14 Fitting Online from Pro Tiler Tools - https://www.*******************/pro-tiler-diamond-hole-cutters-dry-cut-m14-fitting/46965/pro-tiler-dry-m14-cut-diamond-hole-cutter-6mm-pttmd006
Dry Hex: Pro Tiler Dry Cut Diamond Hole Cutter 6mm PTTHD006 | Buy Pro Tiler Diamond Hole Cutters (Dry Cut) HEX Fitting Online from Pro Tiler Tools - https://www.*******************/pro-tiler-diamond-hole-cutters-dry-cut-hex-fitting/47294/pro-tiler-dry-cut-diamond-hole-cutter-6mm-ptthd006
Any of these hole cutters will give you a nice finish if used correctly, if you only need to use them every now and again the Marcrist might be overkill due to the price as that product is really for people who do lots of hole drilling.
If i can help with anything else please let me know :)
Sam
Reply to 6mm Marble Drill Needed in the Canada area at TilersForums.com
Matthew77
