Discuss 600 x 300 Porcelain Tiles On To Walls in the Wall Tiles area at TilersForums.com
Retroelec
Hi everyone.
Thanks for all the advice so far, its going pretty good considering i'm a sparky!!!;)
Going to start to tile the walls and have got 600 x 300 porcelain tiles (Topps Regal Vanilla ones)
Ok so the walls are skimmed plasterboard on the dot and dab and studwork and the tiles weigh 25kg per sq mtr according to the box.
Will I need to put the hardibacker boards on or will i be able to fix straight to the plaster?
I have used mapei aquadefence on the walls in the wet areas and Topps told me i needed some Bal primer for the walls to paint on before tiling.
I am using Bal single part flexiable adhesive is this ok?
I'm fully tiling the shower area and then half tiling the rest of it.
OP
One Day
Before doing anything, as a Sparky you really need to get one of these and familiarise yourself with it thoroughly: :);)
600 x 300 Porcelain Tiles On To Walls | TilersForums.com Filename: {userid}
Now the important stuff is out of the way....
to answer your questions:
At 25kg per sqm (plus adhesive) you are over the recommended weight tolerances. Should you risk it? That's up to you! I can only say what you "should" do.
Topps usually don't know what they are talking about, but in this instance - yes - you will need to prime any bare plaster before using cement based adhesive. BAL primer apd or sbr would be fine.
Not sure if you need to prime before using Aquadefense though...best check the spec sheet.
It's as good as any and better than most.
OP
Retroelec
Thanks for the pointers.
I think I may risk it, the plaster seems very well bonded and I assume that this is whats will fall off, and its well dried as it was skimmed nearly 3 years ago!!
Ok I will prime all the walls before tiling, should i put a few score marks in the plaster or will this make matters even worse?
Regarding this thing below, I don't really want to spend money on specialist tools that I will never use again.;)
Mind you it may come in handy when the tiles fall off and smash my bathroom to bits!!:rolleyes:
All advertising can be removed by subscribing.
This ad should no cover content, please click this contact us with a screen print if it does.
OP
Retroelec
One more thing with this aquadefense is does not say anything about priming the wall first just brush on to plaster.
When I said I have put it on what I really meant was that I have only done a small square to see what it was like and just managed to peel it off fairly easily.
Do you think I should prime the wall first as I guess the tiles will be stuck to this?
OP
Retroelec
This is the one that Topps told me to get for the plaster walls, is this ok?
Seems to just go on undiluted, I’m guessing that if I put it on before the aquadefense stuff it will help a bit.
Reply to 600 x 300 Porcelain Tiles On To Walls in the Wall Tiles area at TilersForums.com
Similar threads
  • Question
Hello, hope all is well! I can most likely help with that! I can get hold of a few different tiles if you wanted to...
I'm Looking For This Tile Undefasa Rajasthan black 600 x 330
Hi I'm looking for this tile - they changed the size recently to 600 x 300 but I need the older size to match the...
  • Question
Every day is a school day as they say. I’ve done it many times albeit not with Marmox boards. The only other option...
  • Locked
The forum is a welcoming place for all. Please be respectful and polite in your replies to other members.
Latest Post
Thanks for visiting TilersForums.com, formerly known as TilersForums.co.uk.
Search Forum
