Discuss 365Drills produce commercial diamond core drills & put holes into VERY hard porcleain in the America area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Deleted member 1779
Do you need to put holes into tiles? 365Drills produce PORSADRILL diamond cores, holesaws, drill bits desgined to grind their way through any type of tile but are targeted to porcelain tiles.
Porcelain tiles are one of the hardest man made stones and are 30% harder than granite so difficult to drill.
Our cores can handle any material including granite, marble, travertine, slate, pottery, glass, mirror, ceramics, composite including zodiaq quartz, crystals, corian worktops. In fact the more exotic and expensive the stone the better our cores work.
We have a time proven (3 year) tool box essential called the Bathroom Fitters Kit. This is it:
And it is designed to cut EVERY hole you will need for a project.
This essential toolbox multipack contains the following parts:
Fixtures & fittings [ wall plugs & rawl ] sizes
6mm x2 (soap dish, loo roll, lights, etc) £8.21 x2£16.42
8mm x2 (shower frame, shelving, mirrors etc)
£10.27x2 £20.54
Standard Service Pipe sizes
16mm x1 (sink feeds, radiator pipes, 15mm) £19.00
30mm x1 (bath feeds, taps, body jets, 22mm) £31.85
40mm x1 (sink waste, shower heads)
£35.96
Anti-Slip Drill Plate (to steady the drills)
FREE
Full instructions on the back of each pack
Total separate selling price £123.77
Now Great Value for money and better than half price!... Only £49.99
To cool the diamond core drills during operation we even have
water sponges which you can fill with water and place next to the core.
Hold water sponge UNDER the core to eliminate dust exposure
for the installer. To catch all the dust to ensure a clean site.
And to provide water cooling to the diamond core drill on tiles.
In addition to all the sizes listed above the core drills can also be used
for other sizes. Example above: Fischer Basin Fixing Kit.
Simply drill a hole into the tile either 16mm or 30mm and remove the plug.
Slip your tile over the bolt for a perfect fit. When the sink is pushed against
it you will never see the hole. Perfect solution ! Saves you buying the 14mm core as an additional expense.
At 365-Drills there are over 37 size core drills to pick from. We have everything in stock for next day delivery.
6mm
8mm
10mm
12mm
14mm
16mm
18mm
20mm
22mm
25mm
28mm
30mm
32mm
35mm
38mm
40mm
42mm
45mm
48mm
50mm
53mm
55mm
60mm
65mm
70mm
75mm
80mm
85mm
90mm
100mm
105mm
110mm
115mm
120mm
125mm
** 1pm cut off for next day delivery **
Our diamond cores are value for money and produce the same results but for less cost. So why not try 365Drills PORSADRILL brand for your next bathroom project and find out if we can last the distance.....
Reply to 365Drills produce commercial diamond core drills & put holes into VERY hard porcleain in the America area at TilersForums.com
Matthew77
