- Reaction score
- 21
Discuss 1200x600x10mm porc on walls in the Tiling Advice | Tile Forum area at TilersForums. USA and UK Tiling Forum
What do you mean by '6mm on tile' ? I would normally back butter, are you suggesting more than just a thin coat?
Question , why 10 mm then 6mm as opposed to 8mm and 8mm . Same bed thickness but use of only one trowel.Porcelain is porcelain, if they’re 10mm, then no different.
10mm on wall, 6mm on tile, trowel all the same way across shortest distance on wall and tile.
Bed in well.
You might find a suction cup would help with handling them.
But you collapse the ridges . Or should doYou need the notches to be staggered. Not lined up or offset which won’t give the desired depth https://www.tilersforums.com/forums/tile-adhesive/ or willl often be different for each tile.
Bed in well.
Reply to 1200x600x10mm porc on walls in the Tiling Advice | Tile Forum area at TilersForums.com
