- Reaction score
- 0
Hi,
I am looking for some advise with tile my bathroom.
Following research online and through YouTube I have tried to learn the basic of tile and the do’s and don’t. I have come to tile my bathroom and following some advice for an ex-tiler I know they recommended I use the dab and dot method to stick the tiles to the wall, due to the larger size tile I am using (250mm x 500mm). However following more research today I have discovered this is a big no no. I have fortunately only laid 15 tiles out of the 100 I need to install.
Is there anything I can do at this early stage to fix this mistake and will carry on forward changing to the comb method. Or will I have to remove the tiles I’ve installed so far?
I’m frustrated Ive followed this incorrect advice but want to make sure the job is done properly and to the correct up to date rules and regulation.
Thanks,
Thanks,
