Got a refurbishment job in a shower/WC of a large twin-unit mobile home.
The walls are 2x1 timber covered in 6mm ply and then when converted into a shower topped
with 12mm OSB board and then tiles.
All this has been removed leaving the studding and it's time to add a decent backing for the tiles.
Trouble is the tiles chosen have a fair weight and not sure that the walls can take it if cement boards
are used. Also a double whammy that these homes do flex a bit and cement boards don't.
I've toyed with a few options and come up with this as an idea, so what do you lot think?
1. Beef up the walls with extra studding to create more surface area for boards etc.
2. Use 9mm sealed WBP plywood on walls and 18mm on floor to act as a liner only & tie studding together.
3. Add 10mm STS Professional Foam backing board to wall and floor and tape/seal joints clips etc.
Idea is to create a good waterproof tile-ready surface, but keep weight down as much as posslble.
Comments really welcome ASAP please as need to start on this Friday.
