Discuss Best Moisture Board & Mapeii adhesive in the Tiling Advice | Tile Forum area at TilersForums. USA and UK Tiling Forum
I am just about to have a bathroom renovation done and have been reading about different plasterboards. My first question is what board would be suitable for larger tiles 120 x 60 and should it just be cement board or although more expensive, marine ply? Or do you have a better suggestion? The walls are going back to brick and being coated in liquid plastic before boards are put up.
My second question is, using mapeii products which https://www.tilersforums.com/forums/tile-adhesive/ for the size tile would you guys recommend?
OP
Hi. Why are the walls being coated with this liquid plastic? , can you be more specific
Rather than PVA, liquid plastic is virtually impenetrable, so as we have access to it, seemed like a good idea. the main query is regards to the tile size, boarding and https://www.tilersforums.com/forums/tile-adhesive/
Dave
That’s why i asked, so we can advise on https://www.tilersforums.com/forums/tile-adhesive/ that will bond to it.
OP
Ahh, I get it, this would go directly on the brick and then a board to be affixed as usual, not sure what board but one that would be able to take the weight
Reply to Best Moisture Board & Mapeii adhesive in the Tiling Advice | Tile Forum area at TilersForums.com
05jtaylor
I've Disabled AdBlock
