Discuss BAL External Tiling Range in the Tiling News; Tile News area at TilersForums. USA and UK Tiling Forum
I received an email about BAL External tile https://www.tilersforums.com/forums/tile-adhesive/ and grout this morning and thought I'd post it to our tiling news area of the forum because there isn't much actual tile news in here. But if you're looking for workwear you're on a winner. :D :D (no offence to our awesome sponsor @************ - it's just this area isn't getting much tile stuff posted to it and that's my bad I guess)
BAL External tile with BAL https://www.tilersforums.com/forums/tile-adhesive/ and Grout​
BAL’s new simple range provides a familiar system for the most-common process of installing external pavers and tiles.
Using the market-leading performance and quality standards, the new external range from BAL provides improved installation performance for the two predominant system build-ups in the UK on Type 1 MOT and Concrete.
BAL's new range includes 4 new products, specifically designed for fail-free external installations.
BAL External Tiling
BAL Priming Slurry Bond for BAL External tile -
a flexible slurry priming coat for bonding external pavers and tiles.
  • Fast and simple to use – only requires mixing with water
  • Provides excellent bonding strength between base and pavers or tiles
  • Excellent coverage of 8m2 at 2mm thickness
  • Brush, roll or trowel on
  • Fully compliant with BS 7533
BAL Bedding Mortar for BAL External tile - A pre-blended mix of cement and graded fillers to provide a semi-dry mortar bed
  • Simple to use, just add water and mix in a force action mixer
  • Can be laid from 10mm for concrete, or 25mm for Type 1 MOT, to 100mm in a single application
  • Gives more than 1 hour working time
  • Walkable in 12 hours n Freeze/thaw resistant and conforms to BS 7533 requirement
BAL Terrace Grout for BAL External tile - Provide the perfect finish with this high performance flexible joint compound for pavers and tiles
  • Super smooth and hard-wearing finish
  • Mixes quickly on-site with water
  • Exceptional bond strength and flexibility
  • Joint widths up to 15mm
  • Available in 4 key colours – beige, light grey, dark grey, charcoal
  • Frost and heat resistant n Conforms to EN 13888
BAL External Tiling | BAL Adhesives and Grout
BAL Level Out for External tile with BAL https://www.tilersforums.com/forums/tile-adhesive/ and Grout
When fixing onto concrete which is in a good condition for tile, but may need smoothing out, BAL is launching new BAL Level Out, a fast-setting one-part external levelling compound for smoothing rough or impact damaged concrete.
Download the BAL External Tiling leaflet for free by clicking here
There's a brilliant YT Live video where David Rowley, the Grand Master of tile and Adhesives, explains in great detail every aspect of the range and there are a few demonstrations by the looks of it. At 45 minutes long I must admit I haven't found time to watch it on this sunny Monday morning. But I'm sure it's top notch.
There will be a few posts related to this on our Tile News blog. Our sponsors Mapei tile adhesives also have levelling systems, adhesives and grout to cater for external tile.
Please reply in the comments with which tile https://www.tilersforums.com/forums/tile-adhesive/ and grout you use when tile externally. Not the time of year for it, but at one point over the last 18 months it might have been the only tile we would have been doing due to lockdown restrictions!
  • bal-external-tiling-brochure.pdf
OP
Dan
Dan
Admin
Hello,
Will BAL Terrace Grout for BAL External tile provide a waterproof seal please?
Hi Jim,
I don't think you need a waterproof seal for a terrace as such but its mention of flexibility does suggest its additives will do such a thing. If you are creating a terrace then you need to manage the flow of water. Consider reading this: Balconies and terraces | Schlüter-Systems - https://www.schluter.co.uk/balconies-and-terraces.aspx
And downloading this: https://www.tilersforums.com/attachments/schluter-external-tiling-pdf.124422/
  1. What type of tiles are you considering?
  2. What is the substrate (floor structure) you're tile to?
  3. How big is the area you're tile?
  • schluter-external-tiling.pdf
Hi Jim,
Hello Dan,
Thanks for your interest.
If you look at the photo, that shows the area I am having trouble with. It is about 2.5m by 1.5m.
I am trying to solve the problem of rain running under the tiles and leaching out on to the conservatory glass roof. This is almost impossible to remove from the glass. I am planning on retiling the area and grouting the tiles (they werent grouted previously) to prevent this from happening, ie prevent water running under the tiles. The substrate is a wooden structure covered with tarmac, then fibreglass matting on that. I haven't chosen the tiles yet.
There they are Dan.
Just to make clear, no water leaks in to the conservatory, only seems to run under the tiles and out on to the glass conservatory roof and stains the glass. It is that problem I am trying to solve.
Regards, Jim
OP
Dan
Dan
Admin
In the case you have, the water will penetrate the grout and https://www.tilersforums.com/forums/tile-adhesive/ and run onto the substrate and down as you describe. It's meant to do that. But I understand the staining.
How the hell is that holding up? lol Looks precarious there in the photos but I'm sure it's using a lintel or something.
I tell you what mate, I'd give Mapei (0121-5086970) and Nicobond (020 8586 4600) a bell. Speak to their technical department. Say Dan has sent you from TilersForums.com who they sponsor, and they'll be able to do you a tech spec and tell you what https://www.tilersforums.com/forums/tile-adhesive/ and grout you need. Though also call BAL on 01782 591120 and say Dan sent you from TilersForums.com. Then see which adhesives you can get in your area, and take it from there.
Nicobond GroutPro Flexible Mapei Tile Adhesive
OP
Dan
Dan
Admin
p.s, Ideally on the new setup you need a small gutter to take the water away from the floor. www.schluter-systems.co.uk might be able to help with this. I'd also use their Ditra matting instead of your fiberglass thing, or look at anti-crack matting. Also consider the weight of all this. Tiles including https://www.tilersforums.com/forums/tile-adhesive/ and grout and other layers and products. I'd hope it's fixed well to the house!
Thanks Dan, I'll follow those tips up.
By the way, there is a 'goal post' frame built in to the conservatory to keep it up. It's been there about 16 years and stayed put fine!
Thanks again..
Jim
Reply to BAL External Tiling Range in the Tiling News; Tile News area at TilersForums.com
05jtaylor
I've Disabled AdBlock
