Discuss hardieboard joints in the Adhesive and Grout area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
plan to tape and fill the joints on the hardieboard 12mm i have on shower area and unsure what to use as there seems to be so many options and types anyone got any recommendations please
thanks
Nearly all cement based adhesive are polymer modified.. 👍 , the adhesive just adheres the fibre tape to strengthen the joint..
Thanks Dave as you can tell I ain't got a clue reason I am asking daft questions just want to ensure I do the prep work the best I can for the tiler
Had a fitter in that took me for a mug and was using incorrect materials was basically cutting corners to the extreme so pulled him off and decided to do what I can myself and get trades in where I know I would be usless thanks again for your help can I ask 1 more question of you I will be putting a mira 25mm tray down that's on 22mm green chipboard that's been well braced between joists how would you fit the tray sand and cement mix or tile adhesive a friend said silicon would be fine but read its not the best way to do it once that's down I will be using 6mm no more ply or rest fo floor then I can get the tiler in can't belive it's been 4 weeks next wendsday with a non functioning bathroom
Dave
S1 Adhesive will be fine , make sure to silicone the tray to the walls as well when you bed the tray in.
Reply to hardieboard joints in the Adhesive and Grout area at TilersForums.com
hoponbaby
