Discuss The New Warmup Ultralight Board - anygood? in the Tiling on Underfloor Heating area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Has anyone used the new 6mm Ultralight Board from warmup. Any opinion, experience with it? Is it worth it. Looking to install it on a Concrete Kitchen floor under El. UFH and porcelain tiles?
Here is what it looks like
Kevbos
I haven't used this yet !! But just read the product description , bit worrying that they describe it as a decoupling membrane , and follow this by saying if screed cracks ,the tiles won't,a decoupling membrane does not stop floors cracking if there is movement upwards or downwards , it just prevents shrinkage and swelling laterally , also they describe it as a great way of cutting costs of running electric underfloor heating!! It would take a few years to gain back just the extra cost of buying these sheets as opposed to the current systems
Lay UFH Cables, then SLC and then Tiling. Why would I need decoupling membrane?
Ultralite Board should do the decoupling from the substrate - concrete.
Kevbos
So what stops the movement from the underfloor heating into the tiles above the cables ??? As they heat up and cool down ?? Think about it ??
Kevbos
You have sorted the first movement problem
Flexible SLC and Adhesive.
Suppose we will find out in 10 years
Reply to The New Warmup Ultralight Board - anygood? in the Tiling on Underfloor Heating area at TilersForums.com
Alex Carr
