Discuss Recommended approach for tiling around stairs. in the Tiling Advice | Tile Forum area at TilersForums. USA and UK Tiling Forum
My staircase is all finished in oak and was just wondering for finishing around the bottom step and other bits would you typically undercut the step which is a big solid lump of oak or cut the tile to match in and grout to the stairs.
Thanks in advance
I agree with Dave, do your best not to get any tile https://www.tilersforums.com/forums/tile-adhesive/ on the oak as it can stain. Also worth checking the silicone on an off cut to check that doesn't stain the oak as well.
OP
Thanks Jon, when laying them im going to mask up the base of the oak and then trim it off after https://www.tilersforums.com/forums/tile-adhesive/ is set. Not sure what you mean by on and off cut...
Dave
Jon means on off cut of the oak incase it bleeds into the oak and stains, use an acetate free silicone and it should be fine. I haven’t had one stain yet.
OP
Apolgies Jon I read that as 'and' for some reason, been a long week i suppose :D yeah I will try that as i have a small piece left over.
Reply to Recommended approach for tiling around stairs. in the Tiling Advice | Tile Forum area at TilersForums.com
05jtaylor
I've Disabled AdBlock
