Hi all,
We've installed a breathable limecrete floor with wet UFH in order to manage problems with damp in the solid stone walls of our cottage (which is also being repointed with lime). We're planning on finishing the floor with limestone tiles. Does anyone have any thoughts or advice on the following:
1) would it be worth putting a levelling compound down first or just tile direct on to the screed (it's reasonably flat already) using a suitable primer?
2) same question regarding a decoupling membrane - and if so, can anyone recommend a breathable membrane?
3) sand & lime or a specialist https://www.tilersforums.com/forums/tile-adhesive/? Breathability is key, so if the latter it would need to be a breathable https://www.tilersforums.com/forums/tile-adhesive/ - suggestions?
Many thanks!
Many thanks!
