Discuss Advice required regarding floor make up in the Tiling on Underfloor Heating area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
I'm refurbing my bathroom after a leak. I've ripped up the old tiles and the 6mm ply they were sat on and the floor boards underneath are in a bad state. They are 20mm t&g and I was wondering if I can replace them with 18mm t&g ply boards. The wife has decided that she wants UFH so I'm trying to keep the make up thickness to a minimum. After putting down the 18mm t&g ply I was then going to fit 6mm insulated boards, then UFH mat, SLC and then tile on top. My joist centers are 400mm, does this sound ok ?.
Demuss
Have you completed the bathroom floor?
I'm doing something similar except not replacing the bathroom floor. After insulation boards, UFH mat, SLC and tiles is going to be about 29mm thick.
What did you use at the doorway to transition into the next room?
Anthony
Ajax123
Get rid of the insulation boards and insulate between the joists. That saves you 6mm
CJ
Insulate between joists as mentioned. 18mm ply, then 6mm hardibacke.
self level to encapsulate cable.......then tile.
Transition threshold bar 👍
Ajax123
I'm tiling over t&g floorboards so aswell as insulating they are providing some sort of support so dont really want to not use them.
If youre relying on a 6mm insulation board for support I'd suggest stop and get someone in that knows what they're doing...
Does anyone, and does the standard allow, tiling directly on top of the cable, encapsulating the heating cable in the adhesive? This is a test question.,I have a customer who knows his stuff. However, he's lacking somewhat in actual knowledge.
Reply to Advice required regarding floor make up in the Tiling on Underfloor Heating area at TilersForums.com
Northern Tiler
