Discuss Weird marks —- help! in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Hi all,
I had my kitchen tiles about 10 days ago, using white marble effect 600x 600 tiles, we have electric UFH. I waited 7 days to properly turn it on. But last night I notice a couple of tiles have a shadow appearing, some are like a 4cm / 6cm oval shape but the largest as the pics attached.
it can’t be a leak as there is no pipes running in the floor as they are in ceiling.
I don’t know what it is, will they go or will I have to break out the effected tiles?
bsc ceramics
Are the tiles ceramic or porcalin
[automerge]1605911186[/automerge]
i ment porcalain ;)
[automerge]1605911358[/automerge]
porcelain.... Got it right in the end
Turbz
I would not think that Grey adhesive would matter, as you would see it on every tile.
They are porcelain so the grey should not seep through in clumps. Does the stains only show when you put the heating on? There could be a fault on the tile but in these situations nobody wants to take the responsibility. As above keep us informed
[automerge]1605988203[/automerge]
On taking them up , hopefully the matting has been self levelled over 🤞otherwise you might struggle getting the tiles up without damaging the wiring
bsc ceramics
the supplier of the tile has told me we should of used white adhesive rather than grey, that’s why it’s staining.
Your supplier is deflecting its porcelain gray is fine but it could be a defect in the the tile,
if its a porcelain faced tile
Turbz
There is a similar thread somewhere on here which shows the exact same problem, and I’m pretty sure they are the same tile
I’m hoping it will go away over time.. I’ve never seen an issue like this and it’s weird as it’s not every tile.
I might have to live with the shadows as taking up all the tiles would be a really big blow and the money involved.
Reply to Weird marks —- help! in the Canada area at TilersForums.com
Northern Tiler
