Discuss wall preparation in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Cath
Hi everyone. In process of having bathroom improved (shower installation over bath) and i will need to do tiling around bath myself due to budget restrictions. Need advice please!
New tiles are 24.5 x 19.5 cm and about 5mm thick. I have purchased Bal White Star adhesive and Bal SBR primer. It is a downstairs bathroom in old cottage.
When i removed the old tiles (which were only on lower area) quite large sections of thin plaster skim came off with them. I chipped away until all loose sections appeared to be off. (Areas up to 100cm x 50cm). Underneath appears to be rough sand/cement type surface. I then filled in these areas with patching plaster but am not happy with it. It appears very soft and crumbly. I think i should remove this and repatch with something stronger? What should i use please? (Plasterboarding is not an option due to it already being a very tight space). I need to get the existing wall surface in a suitable condition to take the tiles securely. Would really appreciate your advice.
Boggs
Can you post a few pictures for us please, we can then better advise. :)
Cath
Hi, Boggs, and thank you. Here are 2 pics of one end, first was pre patching and second is after. Hope this helps.
When you say you filled in with a patching plaster was it already mixed in a tub or powdered? If already mixed might just need a little longer to cure.
The surface behind the plaster is a cement render. Ideally I would have primed that with some dilute SBR prior to filling over. Thanks
Cath
Thank you both. It is Bartoline patching plaster (powder) applied over a month ago. Substrate was just wetted not primed, as i was advised to do, and only apply primer over this top layer, prior to tiling. So much conflicting info! Anyway i think i will remove the filler as i am not confident of it's strength given it can be scratched with a fingernail. Is there a better product i could use to fill (i've seen something called Thistle multi finish plaster that appears similar but not sure?) or would it be better to do as a friend has advised and just use extra tile adhesive on those areas? My concern about that is that the Bal white star recommends a max depth of 3mm and the bare areas are already a depth of about 1 or 1.5mm, and also whether i would manage to get the area level enough, doing that.
Boggs
I would remove the filler back to the cement render, prime the whole area with 2 coats of sbr primer, then when dried skim the areas needing filling with a standard setting cement based adhesive, like Tilemaster Setaflex.
When it’s set prime over these again and fix the tiles using the same cement based adhesive.
Cath
Ok thank you Boggs. I have already bought a large tub of Bal White Star adhesive, would it be ok to skim with that?
Re the SBR, what are the dilution ratios i should use?
acaciaguy
Hello Cath. You would be better skimming with a cement based bagged adhesive - such as the one Boggs suggested. I wouldn’t skim with tubbed
Cath
Hello Cath. You would be better skimming with a cement based bagged adhesive - such as the one Boggs suggested. I wouldn’t skim with rubbed.
Ok thank you. I'll look for standard set Setaflex.
What dilution ratios for the 2 coats of Bal SBR primer, please? Or just neat?
(What is 'rubbed', btw? 🤔)
Thank you for your patience, complete novice here and anxious to get it right.
acaciaguy
my apologies rubbed is a typo. Should be tubbed
Boggs
It should say what the mixing recommendation for the substrate is on the tub.
If it’s Bal Bond SBR it says 2 x water to 1 x SBR for plaster using cement based adhesive.
I would do the first coat at 4:1.
Cath
Ok, thanks, that's all very helpful.
Reply to wall preparation in the Canada area at TilersForums.com
Matthew77
