Hello! I am new here but I have been reading a lot about manual tile cutters on the forum. I am looking to get a quality tile cutter that will last a long time. I already have a wet saw and are looking for a manual tile cutter that can handle 400mm/16" tiles. My budget is around 350$.
I am far from a professional user but I enjoy working with good tools that I can grow and learn with. I like the "Buy Once, Cry Once" motto instead of buying something cheap you will end up being frustrated at every time you use it.
From what I can gather the two brands that seems to be coming up a lot is Sigma and Montolit. So I have looked at a few of those models. It seems that you "cant go wrong" with either but I still like to have your opinion before I decide.
I have a nearby store that sells the SIGMA 3C2 and the MONTOLIT MP 63P3 for the same price (320€ or 350$ or 290£) and I have been looking at those.
I went to the store last light but I only had 5 minutes to check them out before I had to go so I only got a quick look at the two versions. And the store is the kind of store that do not let you try them out...
My quick impressions were that both tools seemed to be quality tools with a little bit of a different design "flavor".
I got the impression that the Montolit had more features and special mechanisms that looked really good but maybe a bit over-engineered (simple is good). And that the Sigma had a bit fewer mechanisms/functions but seemed like more of a "no nonsense machine" that just do the things that you "actually need" really good.
After the few minutes I had to check them out I felt that Montolit was a bit better than the sigma. But since I could not try them out in the store I ended up doing some research here on the forum. And how the tool look like is not nearly as important as to how they feel and perform in real life scenarios. Therefore I am here, asking you guys that have first hand experience with the tools what you would buy if you would chose of these two. Or if you would chose a completely different make or model.
I saw some video of the MAX series also () With push and same type of "swing up tile splitter" with plastic on as the Montolit P3? The one I checked out at the store was the TRACTION pull variant and they did not seem to have the MAX-series.
I also saw this post about the Montolit having an issue with diagonal cutting but I did not quite understand this or if it has been fixed in a revision? If anyone could explain that would be very helpful. Montolit - Sigma vs Montolit - https://www.tilersforums.com/threads/sigma-vs-montolit.81271/post-834077
Which one would you get of the two? Or would you get another model or maybe another brand?
Thanks!
Thanks!
