Discuss Tiling Standards (BS 5385) | British Wall and Floor Tiling Standards - IN FULL in the Tiling News; Tile News area at TilersForums. USA and UK Tiling Forum
IMPORTANT CHANGES TO BS 5385-1 WALL AND FLOOR tile
tile Standards | BS 5385​
As part of the five-year review of British Standards and reflecting changes within the tile industry since 2009 – BS 5385 Part 1: 2018 has now been published. One significant change made was to exclude the use of plywood as a background material for the direct fixing of ceramic wall and natural stone tiles.
Tiling Standards
Clause 6.1.2.7 Other sheets and boards (see also 6.2.3.3) now states:
“The use of sheets or boards that are subject to movement from changes in moisture content should be avoided. Plywood and other wood-based sheets or boards should not be used for direct tile”.
A significant uplift in the use of tile backer boards and a wide variation in quality of plywood available on the market has provided a solid case for the removal of plywood from the standards.
David Wilson, UK Head of Technical Services a member of the TTA Technical Committee said: “Previously it was recognised in BS5385 Part 1: 2009 that tile direct to plywood was possible, providing this was restricted to small areas and be “installed in such a way that they provide a [dimensional] stable and rigid background” the quality of plywood for tile purposes has decreased significantly with cheaper imports flooding the market.
“While higher quality external grade plywood is still available – it is significantly more expensive.
“It is important to consider though that that wood is a hygroscopic material which means that its moisture content will change dependent upon any changes in the environmental conditions on site. Therefore, dimensional stability of wood-based boards cannot be assured there is always a risk to installing ceramic or natural stone tiles onto plywood or other wood-based sheets,
Another technical consideration for wall tile is weight restrictions. Just as a side note at this point, if you don't have a clue what any of this is, then consider a tiling course, and research it well before paying any money. Plywood is deemed to have a maximum weight of tile per m² of 30 kg compared to proprietary tile backing boards which generally are capable of supporting heavier weights per m² of tile (As per table 3 of BS 5385-1: 2018).
British Wall and Floor tile Standards BS5385-1​
“A competitive tile backing board market means that prices are more attractive to tile fixers and contractors. This combined with the additional features and benefits of providing background for tile which are dimensional stable and resistant to moisture and thermal movement. “
However, while plywood is not recommended as a background for direct wall tile, it can still be used as a structural board when overlaid with a suitable tile backing board, particularly where installation of mechanical fixings is required e.g. for mesh backed natural stone where it is not possible to remove 75% or of the mesh backing.
Other changes to BS standards.
Previously in internal dry wall areas it was recommended that tile https://www.tilersforums.com/forums/tile-adhesive/ should cover a minimum of 50% coverage spread evenly over the back of the tile. However, driven by necessity, with the increase in the size and types of tiles i.e. larger formats and thin ceramic panels, now available of the market, BS 5385-1: 2018 advises: “Tiles with a surface area of less than 0.1 m², but which weigh more per square meter than 70% of the background’s capacity to carry the weight, should be solidly bedded e.g. the maximum weight of tile that can be supported by Gypsum plaster = 20 kg; whereas 9 mm thick porcelain tiles, which weigh approximately 18 kg/m², weigh more than 70% of 20 kg (14 kg) therefore, they should be solidly bedded regardless of their size”
British tile Standards included within the scope of BS 5385-1: 2018 are large format ceramic tiles, ceramic panels i.e. tiles with a surface area >1m² (any edge length >1200 mm) and thin tiles
i.e. ceramic tiles and panels with a panel thickness of ≤ 5.5 mm. To reflect this, additional changes have also been made in the minimum recommended grout joint width, dependent on the tile/panel size, e.g. the minimum grout widths vary by tile facial area – an example as follows:
  • For tiles with a facial area of less than 0.1m² with no side > 600mm long, a minimum joint width of 2mm is required.
  • Tiles with a facial area 0.1m² to 1m² with no side>1200mm long, a minimum joint width of 3 mm is required.
And
  • Joints between ceramic panels should be increased pro-rata to panel size (e.g. for a 3m long ceramic panels the minimum required joint width between these panels is 5mm.
Not included in the scope of BS 5385-1: 2018 are:
  • Natural Stone Slabs i.e. stone which is more than 12mm thick,
  • Agglomerate stone,
  • Metal, plastic resin, mirror or glass tiles of a similar construction
Note from Admin: We have collated most of the threads regarding tile standards. Having one thread on the subject should help those out seeking advice regarding British Standards in Wall and Floor tile BS 5385
Soso
broken tile. Don't worry about the gunk on the window that was there before. But if you can see also from this picture the overhang over the window frame. These is because he hasn't set out properly i guess
Soso
Cant see it very well in this picture but there is about a 20mm / 1 inch gap from top of tiles to ceiling. Stuff with caulk and grout apparently but i wouldn't know
Chelly
Hi all, it’s been a while but the dispute is still ongoing. They are now saying that they had to start with a full tile at the bath due to metro tile choice, is this correct? See their reply
We are of the belief that based on the tile selection being bevelled edged, that starting with a cut above the bath, would lead to a greater risk of water ingress as well as less aesthetically pleasing due to the silicone line not being consistent.
OP
H
hmtiling
Nonsense
OP
Time's Ran Out
Ask the client how to set the room out!
That’s why they are paying you - to do a professional job.
Clients away on holiday, that’s okay I’ll send him a photo of how it’s going to look - he’s going to be really confident in your ability.
What’s been done is sh*te and these chancers do our trade no favours.
Must have been on song that night - apologies!
Chelly
[automerge]1562962315[/automerge]
Thought so
108050
Regarding the vertical corner joints, they say.
Wickes Way of Working stipulates that grout is to be applied to all vertical joints as well as joints between wall and floor tiles etc.
Do you also know what size these corner joints should be as some areas are as small as 1 - 2mm?
OP
H
hmtiling
Thought so View attachment 108050
They're wrong(lying) again. All transitions between walls and floors should be siliconed as per https://www.tilersforums.com/forums/tile-adhesive/ manufacturer instructions. Find out what https://www.tilersforums.com/forums/tile-adhesive/ and grout they used and you could get that in writing from them
OP
Just Rizzle
you have a ceiling thats on the wonk re board ceiling and skim the tile looks fine except the slither cut.
alternatively knock the whole house down and get them to get the joists level.:)
ps on my 6th can of Guinness may not be thinking straight but i feel great.
but im leveller than that ceiling lol
Reply to Tiling Standards (BS 5385) | British Wall and Floor Tiling Standards - IN FULL in the Tiling News; Tile News area at TilersForums.com
chris14498
I've Disabled AdBlock
