Discuss Mosaic tile not sticking! in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Never had this happen before. Customer ordered mosaic tile. Traditional black and white checkerboard with 1" tiles. They are very thin, but packing says "for floors and walls". Mesh on back is quite dense. The mesh is bonding with the Mapei adhesive, but once dry, the tiles pop off! We have 3 more bathrooms to do after this one with the same tile. I think the backing and it's glue are the issues, but what can I do about it?
Q
Qwerty
Have you tried giving the back of the sheets a light skim with the adhesive also? Are you bedding the sheets down into the adhesive so the adhesive pushes up through the mesh slightly to make contact with the mosaic?
Any pics?
Joshjupp
Could try skimming back of the mosaics I used biogel last time I done mosaics stuck solid maybe you need to push the mosaics in harder with a grout float
Reply to Mosaic tile not sticking! in the Canada area at TilersForums.com
Dawz84
