Discuss Floor screed in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Leader
Hi Guys
Hoping some of you can give me some advice on a job i have booked in for kitchen floor tiling.
The customer floor has had a self leveling compound (Mapei Restoration)laid down over the top of bitumen. Few concerns i have is that on part of the floor a hole has appeared around 100mm in diameter also the guy who laid it had come back on the customer request to redo some it as it wasnt level down one end of the kitchen.
Now the guy has over mixed it as you can see in the photos their was air bubbles in the mix also cracks have appeared.
Their is no UFH under the screed the screed i was told has been down for 6 weeks , other than the hole that appeared the rest of the floor does seem pretty solid. I was already going to put down decoupling membrane ie BAL or Ditra but i dont want to fix this down if the screed is not good enough and possibly needs redoing. Thanks
107348
107349
107351
Leader
Hi Guys
View attachment 107348 View attachment 107349 View attachment 107351
I forgot to say the tiles that are eventually going to be fitted are 600x600 porcelain 12mm
Spare Tool
Afraid you already suspect the answer...great product Mapei reno screed but used badly!! I wouldn't fix anything on that, do you know if it's even been primed correctly?
Leader
Hi Andy thanks for the fast response i will be honest the customer doesnt know but based on what i have seen i wouldnt want to assume he has.
Arditex na is a great product . You will do no harm in priming and it will actually stop the substrate absorbing moisture so keeping it live for longer to help with the levelling .
Leader
Just a few questions Is the tilemaster prime+grip ok to use as a primer , should i treat the Arditex or Mapei self leveler the same as anhydrite ie when set remove laitance and should i still use ditra or Bal matting on top of the screed once set even though their is no UFH.
L
LM
That primer will be fine once you’ve removed the failed levelling compound completely. If laid correctly Renovation screed does not need any further work to tile to. With a porcelain tile you won’t need to decouple although it’s never a ‘bad’ thing to do with tiles this size, but unnecessary in this case.
Reply to Floor screed in the Canada area at TilersForums.com
po-tay-toes
